hi guys, got a couple of problems with audio in flash and i'm sure there is just a small technicality i am overlooking so would appreciate some advice
the first problem is syncing, there is a sound which needs to be exactly in sync with the visuals, and i was under the impression that the way to do this was setting the play option to 'Stream' - this however is a good 10 frames off accurate (which is still a bit better than just set to 'Event') so i need to offset it manually which is obviously not the way forward, anyone shed any light?
secondly, i have some audio playing at the start of the move, about halfway through the movie stops (just a stop() command which halts all the graphics) - however a sound which plays shortly after the stop still plays
- it is on its own layer and also set to Stream so i have no idea why the whole movie stops but that one layer decides it wont
if anyone can help me with these two points it would be greatly appreciated
