Flash command script
21 Feb 2004
Does anybody know how to create a script(command) for flash so i can batch process to "publish" loads of images?
i want to import this folder
convert them to flash and have html
save as same as file name
Thank you
so i can run the command script in flash to enable me to create swf's of pictures. and i have a lot of pictures. IOt would be tedious to go through each picture, changing the format individually,ok?
why do you need to make SWFs out of them? I reckon its pointless. Flash supports dynamic image loading. You could easily load all your JPEGs into you movie. Are you trying to create a photo gallery or something ?
