Flash 'growing' objects
25 Aug 2004
Reading
Does anyone know how to make a flash object such as a line grow from say a 10pixel width to a 100pixel width (Same height) over a period of time i.e. five seconds or so?
I'm new to flash (not used it for two years and forgot most of what I learnt) and have CS3.
So assuming your using 12fps, that means 5 seconds is 60 frames.
Create a keyframe on frame 1 and draw a line.
Right click the keyframe and make it a motion tween
Create a new keyframe on 61.
Edit the line ow you like
When you play it back it should grow.
How do I add a motion tween? It's not one of the right click options :(
I'm sure I knew how to do this in MX2004!
Do I need to right click and paste motion first, my drawn line dissapears then! Or should the line be a movie with named instance first?
Thanks again!
Got it now, I'm trying to animate lines to show a line graph 'growing' from the vortext to the end of the x axis, sloping up and down is at goes.
Is it best to repeat that motion for each 'segment' of the line graph using layers?
