flash: layers
2 Oct 2004
N.W London
hi
if i have to design a banner for a website with at least 20 layers in flash, how can i acheive that easily? drawing loads of shapes? applying masking, motion guides etc?
i have to ensure the banner consists of different tweening and effects..
whats the best and quickest way to create a banner that looks good with at least 20 layers..
all you flash experts please advise..
cheers
I need 20 layers because thats just a requirement I have set myself..
I already have the website header which I designed in photoshop, but I need to recreate it in flash and make sure it is made up of 20 layers which shows the 3 different types of tweening i.e. motion, classic, shape, colour effects, alpha, blur, gradient, masking and scaling...
If I post the header and as its easy do you think you could recreate it in flash so that it has all the above? so I can see how to do it myself??
here is my current header that i need to recreate in flash
please advise..
Well 20 layesr for that header is going to make it look a bit OTT, but simply start by breaking it into 20 bits and drawing each on its own layer. Then select a bit at a time and make that layer a tween with whatever effect you need.
I can't help but think you are taking the ****. Is this homework that you can't be bothered to do yourself?
wat!?!
no its "im trying to learn flash, kinda of get what you mean, but not 100% as the tuts i followed on kirupa and goodtutorials.com are not 100% working, so could do with seeing what you mean"
so would appreciate some assistance
but if thats too much trouble for you to help as im self learning then yeh you can intrepret it as you so wish...
thanks for your input
