hi guys,
Ive been making an mp3 player in flash which works no problem, i have a dynamic text field reading from the xml file which displays the current song playing. I achieved this from following a tutorial....now however I've been trying to add a playlist which is done in a listbox reading from the same xml file.
This works, however what I cannot get to work is if I click on a song in the listbox, it won't start to play that song...I think it is because I have created 2 different arrays for the mp3 player itself and the playlist, can anyone take a look through my code and see where I am going wrong?
Cheers!
Cheers!
Code:
//Setup sound object
var s:Sound = new Sound();
s.onSoundComplete = playSong;
s.setVolume(75);
//Array of songs
var sa:Array = new Array();
//Currently playing song
var cps:Number =-1;
//Position of music
var pos:Number;
//Load the songs XML
var xml:XML = new XML();
xml.ignoreWhite = true;
xml.onLoad = function()
var nodes:Array = this.firstChild.childNodes;
for(var i=0;i<nodes.length;i++)
sa.push(new Song(nodes[i].attributes.url, nodes[i].attributes.artist, nodes[i].attributes.track));
playSong();
xml.load("songs.xml");
//Play the MP3 file
function playSong():Void
s = new Sound();
s.setVolume(75);
mute.gotoAndStop("on");
if(cps == sa.length - 1)
cps = 0;
s.loadSound(sa[cps].earl, true);
else
s.loadSound(sa[++cps].earl, true);
trackInfo.text = sa[cps].artist + " - " + sa[cps].track;
playPause.gotoAndStop("pause");
//Pauses the music
function pauseIt():Void
pos = s.position;
s.stop();
//Unpauses the music
function unPauseIt():Void
s.start(pos/1000);
//Stops the music
function stopIt():Void
s.stop();
//Music controls
//Play/Pause toggle
playPause.onRollOver = function()
if(this._currentframe == 1) this.gotoAndStop("pauseOver");
else this.gotoAndStop("playOver");
playPause.onRollOut = playPause.onReleaseOutside = function()
if(this._currentframe == 10) this.gotoAndStop("pause");
else this.gotoAndStop("play");
playPause.onRelease = function()
this._parent.pauseIt();
logo_anim_mov.gotoAndPlay(2);
else
this._parent.unPauseIt();
//Next button
next.onRollOver = function()
this.gotoAndStop("nextOver");
next.onRollOut = next.onReleaseOutside = function()
this.gotoAndStop("next");
next.onRelease = function()
this._parent.playSong();
//Stop button
stop.onRollOver = function()
this.gotoAndStop("stopOver");
stop.onRollOut = stop.onReleaseOutside = function()
this.gotoAndStop("stop");
stop.onRelease = function()
this._parent.stopIt();
playPause.gotoAndStop("play");
//Mute button
mute.onRollOver = function()
if(this._currentframe == 1) this.gotoAndStop("onOver");
else this.gotoAndStop("offOver");
mute.onRollOut = mute.onReleaseOutside = function()
if(this._currentframe == 10) this.gotoAndStop("on");
else this.gotoAndStop("off");
mute.onRelease = function()
s.setVolume(0);
else
s.setVolume(75);
//Playlist
// create an XMl object
var sngList:XML = new XML();
// ignore white spaces
sngList.ignoreWhite = true;
sngList.onLoad = function() {
// put the nodes of xml into array
var songArray:Array = this.firstChild.childNodes;
// iterate through song array
// and add songs to the listbox
for (var i = 0; i<songArray.length; i++) {
songList.addItem(songArray[i].attributes.display, songArray[i].attributes.url);
// when xml is loaded play first item
playSong.play(songList.getItemAt(0).data);
// highlight first song in listbox
songList.selectedIndex = 0;
// create a listener that responds
// to changes in the listbox
var sngListener:Object = new Object();
sngListener.change = function() {
// play the item selected in listbox
playSong.play(songList.getItemAt(songList.selectedIndex).data);
// register the event listener to listbox
songList.addEventListener("change", sngListener);
// load xml file
sngList.load("songs.xml");
