Hello,
Which is the best Flash Memory to use with a digital frame...? I just bought one ofr my mother and the memory card I purchased with the card would not read in the fram for some reason. I this it was because it was not compatible. I used an Kingstone HC and it would not read this card for some reason but would read the same SDHC memory flash in a SD to USB adaptor, work that one out then.
It stumpt me I must say... the fram does take the following:
SD/MMC/MS/XD
and USB
Being SD I think it only takes a standard SD Secure Digital and not SDHC which would not read the card.
Thanks.
SD/MMC/MS/XD
and USB
Thanks.
