When you have a .fla file that's got a tween on it, and you then play the corresponding .swf file, it loops over and over again. I know that when you play the .swf file you can manaually go in and take the Loop setting off, and that way it'll only play the once, but how do you set the actual .fla file to only make it play the once?
I want to put my .swf on my web site as a banner, but don't want it playing over and over again. Just want it to run the the once when the site is initially loaded.
Is this possible?
I've just started playing with Flash for the first time, so I'm on a steep learning curve
Is this possible?
