I've got Ubuntu 9.10 (64bit) installed and Adobe Flash Player 10 seems to be playing up in Firefox 3.5
Sometimes it won't load, sometimes it will but none of the buttons in the flash object works, and other times it'll work, then I'll change tabs and the flash objects will disappear.
One of my housemates on a similar config has the same issues, I was just wondering if anyone else did, and if so if anyone has fixed the issues?
Thanks for any help!
