I have just created my first website in Flash 8 Pro. I didn't build a preloader into it but now I'm wishing I had! Since all the frames refer to each other it would be a pain to move them along the timeline and go through manually updating all the links. Is there a way to make a separate .swf that will appear while my site loads in the background?
It only needs to be 3 or 4 frames, just to let visitors know they haven't crashed.
I've got a feeling there should be a very simple solution to this but I'm not having much luck when trying to search for a guide. Can anyone point me in the direction of an appropriate tutorial?
Thanks!
Thanks!
