I just upgraded to ubuntu 9.10, and it screwed up flash. I ran firefox and noticed that it now seemed to be lacking flash, so i try download the .deb installer to get it working again.
I try double clicking the .deb but find out that doesnt work as it gives a file permissions error, so i try to check synaptic package manger to see if i can install using that, and it instantly gives an error about flash and no archive file or something then instantly closes.
So, after a quick google i find that to install the .deb file i just use sudo dpkg -- install ~/Desktop/install_flash_player_10_linux.deb the problem is, i get errors about no alternatives for iceape-flashplugin. then gives some warnings about old pre-removal scripting returned error exit status 2, then some more errors about that iceape thing then it aborts the upgrade.
So, what do I do now? 9.10 seems to have ****ed up flash, and who knows what else, I cant use package manager now as it closes right after displaying an error about flash. How do I get this all fixed fast?
If there is no simple way of fixing this quickly ill just get rid of ubuntu, its not worth the hassle of downloading upgrades that it tells me about if they are going to screw up my system.
