Flash won't install with vista
18 Oct 2002
I've been trying for hours to get flash to install with vista. I am running the 64bit version but when trying to install flash im using the IE from the x386 directory. When i go the flash player download page it just gets stuck there and doesnt download.
Any ideas?
Kev
Any ideas?
Kev
Had the same problem with my 32bit home premium version - hope this solution works for you!
Grab the uninstaller from [url=http://www.adobe.com/shockwave/download/alternates/[/url]
Reboot into safe mode and run the installer to remove any flash leftovers.
Search for a flash player 9 standalone installer.
Right-click and and select 'run as administrator'
Also, if you have a pc/laptop by the likes of packard bell, dell etc, check for any preinstalled plug-ins first, although the flash uninstaller should get rid of those.
Solved the problem last night with a solution similar to the one you posted above! Thanks for the taking the time to reply.
Please close thread.
Kev
