Flashed going 56 in a 40
15 Nov 2007
Sheffield, UK
I could have killed a child! But luckily this was on a motorway at 9:30pm :D I was joining the M1 southbound from the M18 junction and then immediately taking the next exit for the A57 (about 1 mile of road). On the M18 it was variable speed signs at 60 for quite a while - thought nothing of it and just went kept around 60. Its 2 lanes to join the M1 and I was in lane 2, which put me in lane 2 of the M1 since lane 1 of the merge gets is own lane. Saw one gantry that still said 60, then doing checks etc to move over to lane one to exit and briefly saw the next sign but didn't really clock the number on it as had other priorities with the manoeuvre. Once in lane and quite close to the camera I saw it flash another guy and I clocked it had dropped to a 40, braked a little but not really enough time to drop from 60 to 40 so ended up going around 56 through the camera and got flashed. I think it was dropping aggressively as they were coning off lanes further down for night works
The above was 2 and a half weeks ago and I've not received anything yet so I think I must have accumulated some good karma somewhere. Thanks for listening to my ramble and carry on :D
Hard to make out some of your post but if a variable speed limit I believe there is a brief grace period between a new limit coming live and enforcement.
A variable speed limit will definitely give you some grace after the speed change.
If you are the registered keeper (i.e. not a leased car), and haven't heard anything in 2 and a half weeks, you're probably ok.
