Flashed Vapor-X 5870 with Asus Bios and lost the Display Port
13 Nov 2007
I flashed my Vapor-X 5870 with Asus Bios and lost the Display Port ... flashed it back and all is well again ..
What BIOS should I use to flash so that I can get 3x1920x1080 Eyefinity up & running and still unlock the voltage/clocks?
I don't think the Vapor-X has the required hardware to allow voltage modding - unless you have one with a black PCB you'll never get it working, as they removed it from revision 2 Vapor-Xs (blue PCB)
It's a version 1.0 with voltage control under the asus BIOS ... already verified that by getting it to 975 @ 1.25v but the DP does not function with the Asus BIOS (at any speed)!
Problem solved - I edited the BIOS with RBE to raise the CCC clock limits and use MSI AB to set the voltage/clocks on startup ...
Now @ 1000/1300 @ 1.3v - will stay with this for a bit.
