Flashing Amber Power Light on DELL 5150 PLEASE HELP
11 Feb 2011
South Yorkshire
I have a dell 5150 which my friend gave me and it has a flashing amber light and wont turn on.
I connected 24pin and 4 pin connectors to the PSU tester and I noticed on the 24 pin the -5 didnt light and was wondering if anyone can tell me what this means.
Is it the power pack thats duff?? Or the motherboard, I'm suspecting power pack as I got it working yesterday
I'M guessing that LED off means there's a problem with that voltage. Use a multimeter and probe the -5v wire and see what it's reporting. Not sure what a PC needs with negative 5v but I'm guessing it must be slightly important as all PSUs have it and clearly your system won't pass it's good power test.
Hmm I retract my statement as it seems newer PSUs don't even include a -5v rail any longer.
See here..
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Still it's a bit misleading for the PSU tester not to highlight the removed requirement for the -5v rail and that it won't need to light in some cases.
Of course on this Dell 5150 it may be required by the motherboard and your PSU doesn't have it. The Dell 5150 is pretty old now isn't it?
From the sounds of it, it could be the Dell's inbuilt surge-protection.
If I remember rightly, you need to take the side panel off and unplug the 24-pin power cable from the motherboard, then press the power button on the front for a second or two to discharge any residual charge in the circuits.
Plug the power back into the mobo and fire up as normal. Happened to me a couple of times with my Dell machine.
System Lights
Your power button light and hard-drive activity light may indicate a computer problem.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid amber
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance (see your computer Owner's Manual for information about how to contact Dell).
Blinking amber
A power supply or system board failure has occurred.
Check the diagnostic lights to see if the specific problem is identified. Also, see "Power Problems" in your computer Owner's Manual.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Power Problems" in your computer Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance. See your computer Owner's Manual for information on how to contact Dell.
Hard-Drive Activity Light
Problem Description
Solid green
The hard-drive activity light is on when the computer reads data from or writes data to the hard drive. The light might also be on when a device such as a CD player is operating.
More info on your system you can get from the link below,
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1114195
also oyur system specks can be seeb from the link below,
http://support.dell.com/support/edocs/systems/dim5150/en/sm/index.htm
