Flashing troubles...
Permabanned
9 Mar 2010
Fabric Nightclub, London.
Hi guys, just trying to flash my 6950 with just the unlocked shader bios.
Everytime I try to flash with an ASUS bios, Winflash keeps coming up with "Subsystem ID Mismatch". Any ideas why?
Cheers Guys :)
cheers mate, but I've already got the full 6970 bios flashed onto it :)
Just trying to unlock the shaders while keeping the stock memory timings, and also unlocking the voltage control ;)
Just doesn't work when I try to use the ASUS 6950 unlocked shader bios :(
just use the mod to modify your 6950 bios instead.
If you're stumped on how to unlock your own shaders then send me a message on Trust and we can talk. I could do it for you with your original backed up BIOS, takes less than a second :D.
