- 17 Apr 2009
- East Northants
Does anyone play OP FP online? If so, what servers do people play in, as all of the ones i find seem to have very high ping.
Does anyone play OP FP online? If so, what servers do people play in, as all of the ones i find seem to have very high ping.![]()
This is why you should read up on games before you buy them![]()
WEll in all honesty, it says 'dedicated servers' on the box. You should sue.
Luckily I didn't buy this game, just got it free with my cpu, is it worth installing by the way? If MP is **** what is the single player like?
the reviews were in the most part singing its praises. if you got it on release day then how were you supposed to read up on something only reviewers knew anything about![]()
Well, I don't mean to sound smart, but to be honest you can't trust a lot of reviews these days either. You're much better off looking at the user reviews over at Metacritic or wandering in here to see if there's a massive thread complaining about the game.
You can almost take it as given that if a magazine gets an exclusive review, with a full splash on the front cover, that they're doing so in return for a favourable (ie 85% +) review.
If you want to know what a game's like these days, the only reliable way is to ask other gamers.
If you buy ANY game on release day, ESPECIALLY IF THERE'S A SUSPICIOUS LACK OF A DEMO, you deserve whatever you get.
you have to use wasd to control the radial menu and q to close it again afterwards very frustrating, as you cant move while ordering, and then you forget to close it accidentally try to move and order them to just charge in>.<
I found it easier killing my bots off and playing solo tbh.
With a 360 controller its a lot easier to play as opposed to using a keyboard in conjunction with the quick command radial.
