Flashy case for my new build
28 Mar 2016
Got a build here, recommended by ExRayTed (thanks again) and it's looking good. However was thinking of getting a bit more of a flashy case (windows on the side, maybe some LEDs etc). Wondering which ones will fit the parts I'm wanting to put inside with decent cooling. Not looking to spend more than £40-£50 on the case alone. Here's what I've got so far including the case recommended:
My basket at Overclockers UK:
1 x Raijintek Arcadia Mid Tower USB 3.0 Case - Black= £24.95
1 x Intel Core i3-6100 3.70GHz (Skylake) Socket LGA1151 Processor - Retail= £99.95
1 x Kingston HyperX Savage 240GB SSD 2.5" SATA 6Gbps Solid State Drive (SHSS37A/240GB)= £59.99
1 x KFA2 GeForce GTX 960 Reference 4096MB GDDR5 PCI-Express Graphics Card - Retail= £155.99
1 x Super Flower FX 450W '80 Plus Bronze' Power Supply - Black= £42.95
1 x Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)= £36.95
1 x Gigabyte H110M-S2H Intel H110 (Socket 1151) DDR4 Micro ATX Motherboard= £46.99
1 x Panram Ninja-V 8GB (2x4GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (PUD42400C154G2NJK)= £23.99
Thanks for reading and any recommendations are appreciated :)
You could spend a little more and get the Phanteks Eclipse P400s.
That'll give you colour matched and changeable LEDs, fan controller, window and noise dampening.
That's my favourite looks-wise
