Anyone used them before as I want an ethernet connection from the master socket at the front door to the back of the house in the dinning room so the nas can sit there instead of right at the front door.
If I use round cables it'll need to go upstairs into the attic and then down whereas the flat cable would go straight down the hall way under the carpet. So the flat cable would probably half the distance of the run but I'm not sure how good the flat cable would be?
