Flat Sound :(
31 Mar 2011
Hi folks!
I have an Asus Crosshair Formula IV motherboard with onboard "X-Fi" but the sound is...well..flat. I'm using Corsair HS1A Headphones and the mid to high (treble) sounds muted. It was the same on my old Plantronics .audio 90 headphones.
I read on a few sites that the sound-chip on the Crosshair is actually a Via, but with Creative software on top of it to give it the "X-Fi" but to be honest i aint liking this sound at all. I put my old Audigy 2 ZS into the PC and noticed a slight difference in the audio via the headset, slightly clearer midtones but the bass was still lacking slightly.
I'm thinking about grabbing this... http://www.overclockers.co.uk/showproduct.php?prodid=SC-012-AS
I aint bought a new soundcard since buying the Audigy 2...will i notice any difference via the headphones? I aint too worried about the speakers since i use headphones almost all the time.
To be fair one of the major criticisms of the HS1A 'phones is the lack of bass, so I suspect that buying another sound card isn't going to quite do all that you're after.
I had the Hs1 (usb version) and yep the lack of bass was awful. I ended up sending them back and getting about 3-4 diff pairs and sneding them all back under the distance selling law. It seems Most headphones have a lack of bass :( i ended up going for Hd555 which were.. good but well over priced (please dont hit me HD555 fans lol)
However.. i do feel you would see some improvment getting a soundcard and changing the bass in the Eq up some and messing about with it. It wont be a WOW improvment but it will deff have the "OOo.. thats better" effect. :) Should do anyway. :) hope this helps some.
