Flat Tyre
14 May 2009
Hampshire
So there I was driving home and then suddenly a loud bang!
I managed to hit a pot hole that I must have not seen and now my tyre is as flat as a pancake.
So I need to get it replaced and due to the time, if I change to my emergency tyre, it will be too late to take it to the garage.
Can anyone recommend any decent mobile fitting company's?
Also, it's a FWD so should I replace both front tyres?
From National I can get 2 Barum Brillantis for £82 inc fitting.
From eTyres, I can get 2 DUNLOP - SPORT BLURESPONSE tyres for £108 inc fitting.
The Dunlops seem to have better reviews online but I don't know if I should get 1 or 2!
I used SOS tyres last year and found the service to be very reasonable. I had a Goodyear AS2 fitted for not much more than what the tyres + fitting would've cost had I purchased the tyres from camskill and taken them to my local fitters. Give them a shout to see whether they service Chichester area.
Edit: Talking about Event tyres. I did originally book them but after confirmation they called me back to let me know the tyre I wanted wasn't in stock. Whilst the service itself was fine, It would've saved me a bit of hassle had they just told me when I booked in! The SOS guys used to be employed by Event tyres, or so they say.
Well I've check the tread on the other tyres and 1 needs replacing anyway, 1 is half-way and the other is OK.
Debating to replace all 4 and be done with it.
