Flawless widescreen and widescreen fixer alternatives???
27 Apr 2012
London
From time to time I get some single player games that don't run properly with a 3 monitors setup, so i use flawless widescreen or widescreen fixer to be able to play, but some games are not support or don't work properly with them.
Is there any other alternative program for that?
Just as a note, if you download this programs, DON'T use on online/multiplayer games, you could get banned.
http://www.flawlesswidescreen.org/
https://www.widescreenfixer.org/
My experience is that, pretty much, if a game doesn't natively support multi-monitor and Flawless and Fixer don't help, then that game won't work on multi-monitor and I have to drop back down to running it on a single monitor. I realise this is only two or three mouse clicks to change once your system's set up, but it's still annoying having the tech and the game not playing ball.
Sometimes you can get lucky and widescreengamingforum will list a fix for a particular game, but mostly if it doesn't work with or without Flawless/Fixer then you're scuppered. :(
i dont mean to hijack but any tips for limiting mouse cursor when using 2 screens?
mabe its just game controlled and nothing i can do but thought i ask >.<
Flawless widescreen allows you to custom set your resolution and HUD/position. Have you tried that for the games that are not "properly" supported?
yeah, I did, sometimes it helps.
I always saw posts from WSGF but never actually joined the forums, I might give it a go :)
I was just wondering if there was another program like that, but I don't think so.
