Flexible adhesive recommendation?
22 Jun 2009
Norwich
Hi
My waterrower developed a leak and I've taken the tank apart and cleaned the seam.
I phoned the company and they want £100 to re-seal the tank :eek:
All I need is to use some flexible adhesive...
Can anyone recommend any glue that can hold the seal and withstand the vibrations when in use?
Cheers :p
Have heard it is supposed to be more like actual rowing as you are spinning the blades through water, so same resistance..... I have a feelign I would always need to go and pee with constant water sploshing noises going on.
That is if you would be able to hear that over my 'just about to die' breathing
