I have joined 2 rads with a short section of tube but it is squashing at the centre of the bend. I'm using straight G1/4 compression fittings. I suppose my best option would be to get 2 90deg fittings and then just a straight bit of tube.
However is there anything I can get to squeeze the tube back to a round shape as this can be done easily with fingers. This would save me having to drain the system (again) if I changed the G1/4 fittings. All working well enough at the moment but it isn't optimal.
Andi.
Andi.
