Hi all.
This suddenly just happened to me. This new(ish) machine from OCUK I have bought has 2 970's for SLI. Just before I was in a game that I had been playing fine for about an hour and a half, when I started getting minor flashes or flickering. It was in half the screen, like a solid colour for a millisecond. Didn't put much thought to it at first, but then it started to become full screen and the flashes more frequent. It looked a bit like screen tearing but with solid colours.
I made sure I hadn't inadvertently changed some vsync settings which I knew I didn't. Checked all cables were tight. I have afterburner for on-screen monitoring of temps, they rarely go above 60. So I was stumped, I restarted my machine again and fired up a few games and to my horror, the flickering had become much much worse, absolutely constant and the FPS in those games hit rock bottom. It crashed a few as well.
Then tried a few other things like adaptive vsync and other sync settings, changing pre-rendered frames, and other things in the control panel to no avail. Finally I turned off SLI, lo and behold, it worked. The flickering had stopped. It had something to do with the bottom card.
What's telling is how I was playing a game that was ok for a while, more than an hour before it started, in that game. And it got worse and worse. I only got it in games though. Surfing and anything else seemed to be ok.
So, before I contact OCUK, maybe there is there something I can do? Things I've tried:
Drivers up to date
Making sure all cables are tight
Different vsync settings
Actually many settings in control panel, all to no avail.
Drivers up to date
