- 20 Mar 2007
- Swansea Wales
Flickering using extended monitors -58XX -
Ok...well...
Bought a new power supply, Corsair HX 850W, when I was getting problems with my 5970 to replace the Jeantech Modular 700w - I was going to upgrade, now is better time, than any -
But, I still get flicker on the second monitor, when using, extended display and duplicate display, when you drag a window about on the main monitor. I don't get it if I use the second monitor on it's own.
After doing searching on these forums and others, it seems, that quite a lot of people are suffering from this - I'm not sure if this is just a windows 7 problem -
Who else suffers from this ?
And has anyone who did, fix the problem ?
Or, are we going to have to wait for a fix from ATI/Microsoft ?
Your help is very much appreciated. Thanks in advance.
Ok...well...
using GPU clock tool means you get no power saving features so the card is running on full juice all the time, nothing wrong with this but its nice to have a cooler running card when idle.
