Flight to anywhere
16 Oct 2007
UK
Does anyone know of a website that lets you find a flight to anywhere, from a particular airport?
Looking for a random weekend destination, flight as cheap as possible. Need options!
SkyScanner will do this but unless you have free accomodaton its kinda pointless as its only half the story.
Would you rather pay £10 for a flight and £200 for accomodation or £100 for a flight and £100 for accomodation, for example?
Google wasn't bringing up anything other than the usual sites with the usual text - nothing about finding a list of flights from a particular airport
I'd use Skyscanner, but also Easyjet. They're likely to be the cheapest non-awful airline, and I was looking earlier and there were flights to everywhere across Europe, + Morocco, for ~£30
You should also consider Eurostar to Paris, or the cheap trips Megabus does to the continent (very cheap).
Thanks, appreciated. Eurostar an option. It was only for a weekend break so megabus might be out!
Cheap accommodation is always available!
That would mean getting down to London though if the Eurostar was to be an option. If it was then flying from Stansted/Luton/Gatwick/Heathrow etc would also become an option wouldn't it rather than being limited to Newcastle? Although I'd agree in general that Eurostar can be a good alternative.
Cheap relative to the other accomodation in the location might still be quite expensive in absolute terms but if it's somewhere that a budget airline flies to you'll probably be ok.
