floating divs
30 Nov 2003
I have a problem which is most likely pretty straight forward.
What I am trying to do is have have an image and then along side the image on the right hand side some text.
I created two divs and floated them left, one for the image and another for the text which has worked and given the desired affect.
The problem is I want to duplicate this but a few lines below for another set of images and text. What I have currently done obviously floats the next set along side the first set.
Ideas? :)
hi mate,
you could either make sure the container can only fit 2 columns (i.e. have the floated divs 200px wide and the containter < 600px, alternatively stick each two in another div with clear:both; to make sure nothing gets floated along side?
just some ideas mate, hopefully one can be of help :)
Cheers guys, after a bit of fiddling I came up with this:
Code:
<div class="artThumbs">
    <a href="images/big1.jpg" rel="lightbox"><img src="images/thumb1.gif" alt="electronic hand" title="electronic hand" width="120" height="85" border="0" class="artwork" /></a>
	<span class="artText">test text</span>
	</div>
CSS:
Code:
.artThumbs{
margin-bottom:5px;
float:left;
clear:left;
.artText{position:absolute;}
It works fine but does this look like a good way of doing it? It breaks my footer for some reason but I'm sure I can figure that out.
You don't really need to give the span a class as you can use a selector to target it. This works because there is only one span element inside your artThumbs divs.
div.artThumbs span {
#code
