Hi there,
I've been trying for hours to get this problem sorted ... but I just can't find a solution!
My problem is with CSS and floating images inside of a div. When the image is floated left or right the div doesn't reach the bottom of the image, it's just completey ignoring the image altogether!
One of the websites i've come across is this, which should explain my problem best.
Things worth noting are that its happening on images being float both left and right, and if I set a height for the div (height: 500px) the problem is solved (but i can't do that as i won't know the height of every div unfortunatly)
My CSS...
Things i've tried...
Thanks for any help,
Steven.
My CSS...
Code:
img.left { margin: 0 5px 0 0; float: left; }
#section
margin: 15px 0 0 0;
padding: 0;
width: 580px;
font: normal 10pt verdana, arial, helvetica, sans-serif;
background: #ffffff;
color: #000000;
clear: both;
- Applied 'clear: both;' to the image
- Applied 'position: relative' to both the div and image
- Applied 'display: block' to the image and div
- Applied 'height: auto' to the div
- Applied 'min-height: 100%' to the div
- Applied 'min-height: auto' to the div
Steven.
