- 21 May 2007
With my new 280 winging it's way to me (will citylink be delivering today or did they do no pickups on the BH?), I am now faced with a dilema regarding my BFG8800GTXoc2.
Basically, when I last rebuilt my machine following a mobo failure, for some reason I plugged the DVI lead into the other port from which I normally use.
Purple screen. No amount of wiggling of the port produced even a flicker of a hint of any evidence that the green leg of the signal was there, also no visible bad solder tags on socket, so I'm thinking it's either a broken pin receiver on the inside of the DVI port (can't see how though, this was the first time I'd plugged into it), or an actual electrical fault.
The choice is........
Do I flog it on the cheap to some needy soul with a single monitor on the MM?
Or
Do I RMA the thing to BFG, get a shiny reconditioned one and then keep/flog that one.
The card's been in and out of a few slots in it's day, so the edge connector looks a bit worn, they wouldn't refuse an RMA for that would they?
Or
