- 4 Oct 2004
- Yorkshire
Hi,
I've recently upgraded my ageing AMD 64 3500+ to an Opteron 170 which I intend to overclock. Only problem being that my temps are high (50' idle) even when using an Arctic Cooling Freezer 64, and yes, it's running at full pelt then too. The ambient temp in the room is pretty high (27'), but I'm suspecting the airflow in the Coolermaster case isn't too great.
Would upgrading the 80mm fans (to YS-Tech, Delta or other fans with good CFM) make much difference or would I be better purchasing a case with 120mm fan mounts? It would be a pity to get rid of the Coolermaster as it looks great.
Cheers
Paul
Cheers
Paul
