Flogging a dead horse!
11 Aug 2003
Taunton, Somerset
Evening all,
I have a pc in the front room that is used for surfing the web, playing music and writing the odd document.
It is an old PC its a P4 2.6 with HT, 512MB RAM (dual channel) on a Gigabyte 865GBF mobo. It uses the onboard graphics and is currently is attached to a 17" TFT.
I don't know if its possible to use this for connecting up to a 32" TFT TV. My thoughts are to put another gig of RAM and a graphics card (AGP).
Is there any point doing this or going totally the other way buying an ATI HD 3650 or is there just too much of a bottle neck?
The other thought is that I run the F@H project and could use this card to boost my PPD output
Any card can drive a TV.
Huge screens or not, they are still usually low res, and even when the screen isn't, the video is. I only upgraded my Gefore4 in my media machine by default, it was still wotking a treat.
Might be different if you plan on playing bluray and stuff.
will be watching some HD stuff via mkv files
HD stuff from MKV files overloaded my athlon1800+, vid card seemed OK though. Your CPU should do a wee bit better.
Not sure if a better video card would cause more or less strain on the CPU for video playback......gut feeling is that it'll have little effect because video is usually done by overlay.
I would forget it, my girlfriends PC can barely cope with 720p episodes of Lost in .mkv format and that's a P4-3Ghz. Jerks about all over the show, you won't have a hope with 1080p stuff.
OK so OCUK offer 3650 (512MB) or x1950pro(256MB) is the x1950 quicker even though its got half the memory?
any idea of energy consumption?
Sorry - meant to say 3650 instead of 3850.
More than enough power, and should be able to be passively cooled as well, normally a pre-requisite for an HTPC.
