- 22 Feb 2014
The plumber poured self levelling in the bathroom and used a strip of wood in the doorway, but he has set the strip of wood in the wrong place.
It should have been halfway across the bit where the door sits when closed, but he has set it up to where the door shuts when it is closed, so now If I want to fit a door bar, half of it will be visible when the door is closed.
I guess what I need to do is cut back the self levelling by about 20mm so that I can fit the door bar in the correct place.
What is the least messy way of doing this ?
