Looking for some advice on anyone that's carried out installing insulation for a suspended timber floor.
Currently I've got no insulation underneath and we are taking back one of the rooms to the original pine boards, the joists are 150mm in height and its roughly 400mm between centres.
I've read old buildings it's better to use natural but at the same time I read up some people have just used mineral wool as its a lot cheaper and thermally almost the same.
Issue is what thickness and type of insulation, I did think the full 150mm but I believe my insulation and joists would block ventilation to the sub floor as the joists are sitting on sleeper walls. The house has good ventilation currently underneath with several vent bricks.
The room is about 25m2 however I'm considering doing the full ground floor at around 65m2 as I've read the benefits can be substantial.
If anyone can shed light on this it would be helpful.
