Floppy drive in V600 conundrum...
Permabanned
24 Nov 2006
I'm looking to get the Lian Li V600 case for a build for my dad and want to fit the Mitsumi 7in1 Floppy & Media Drive but I don't see how that's possible. Is it? I'm not sure if this case comes with one of the Lian Li floppy bezels, but even if it did, how does this fit into a 5.25" bay. And then, even when it's fitted, I can't see that the additional memory card slots on this drive will be accessible as the bezel doesn't seem to have the space!?
What's the solution, if there is one?
:confused:
You need to get a bay converter.
If it is coming with them then as Snapshot has said just screw it in.
Do not worry about the bezel, they are removable (take it your looking at a 1000).
My TR3a in a converter.
