Flow path - Requesting adivce
12 Jun 2014
Manchester
Im currently in the process of building my first full custom loop.
I will be cooling the following items
Mosfet + VRM
Chipset
Cpu
2x Gpu
my original idea was to route it the following way.
Res* -> Pump -> Chipset -> CPU -> Mosfet -> 360 rad -> GPU 0 -> GPU 1 -> 360 rad -> 240 rad -> Res*
But I would like to know if anyone had any suggestions to this end?
I have provided a diagram of two ways I envision the loop.
But there is also a template if you care to suggest additional methods.
(TEMPLATE)
Loop 1
Loop 2
Thanks in advance for your Help and Experience.
it really doesnt matter which way you go as the temps will equal out across the entire loop.
its just down to which looks best in your case and is ideally the shortest way of going.
bolt the bits in and work out the best way of going that suits your and the case.
So by the sounds of it Loop two would be the better option as it would result in a slightly shorter loop.
My main concern is that I do not know how much the water heats up at each component, but by the sounds of it not much.
remember once the loop is running the water wont be in the same place for long, it draws the heat out as it passes through. I think loops two looks better also.
