3 or 4 months ago (approx.) I upgraded /swapped radiators (triple in roof + single in bottom of case) I drained the system , took out the ‘old’ rads and (having flushed through the new rads with de-ionised water) installed the new.
I had been using Mayhems Pastel - Ice White Coolant 1L and decided to continue the tradition so , having bought a new bottle, I filled up etc.
No problems – cooling was a little better - apart from it took a day or so for things to settle .
On Sunday I was installing a new ssd and looked to give my computer a clean at the same time and was concerned when I noticed the water in the res. – to start with it looked to have lost about ½ however upon closer inspection I realised that what in fact appears to have happened is that the white colour has dropped to the bottom so looking at it the bottom half is coloured white but the top half is semi –clear.
Apart from lacking colour all appears to be working fine - temps are good (ran Intel burn and heaven) with temps dropping very quickly.
Is this something to worry about ? What action(s) if any should I take ?
Thoughts appreciated
