I disagree with Biffa (not offence by the way) as its not "DYE" that clumps of causes build up its actually inhibitors that brake down in injection blocks and this cause's a bio build up of film as the partials brake down (separate) when being put under high pressure in water blocks. Then the dye doing its job will then colour the slime as it’s supposed to do giving the effect that the dye has caused this in the first place which is incorrect. If look under a microscope you will see the mess is actually the inhibitor.
Holy thread revival batman!
Try picking a more recent thread, as you'll see I've been advocating the same things you just said about it not being the dye that causes the blockages rather other additives in the premix.
However dyes do stain your kit. Yes you can clean it but personally I'd rather just use coloured tubing and save myself the hassle.
I disagree because of the fact the PT nuke and Kill coil effectively work against each other.
One or the other not both. As we have seen here, it erodes tubing casuing it to cloud.
I will choose pre-mix always however those that are still concerned about dyes clogging, staining their loop etc you can get clear fluid which IMO is a lot less hassle and easier to maintain.
Agree Nat, again I stopped advocating both a while back, it was only when I found the mess in my blocks that I went looking for alternatives and the reccomendation at the time was both, since then we've all seen what PT can do to some tubing, not all mind but some. I have no clouding in the system I have both in but then the tubing is black and silver solid colour
But yes kids don't use both, in fact don't use PTNuke at all just use a silver coil
However the "I will choose pre-mix always" stance is an interesting one, a commercially sensible one sure perhaps, but considering that the only thing you get from pre-mix is umm.. pretty colours, why bother with clear pre-mix when plain ole distilled/deionised and a silver coil is as good if not better?
YMMV of course and I know you have had better results with some premixes in your system than others.
What OcUk should do I reckon is get commercial with Distilled and package white label own brand OcUk Distilled and silver coils
I'd probably lean more towards using a dye bomb in distilled/deionised than premix now if I wanted colour but thats just me.
Coloured reservoirs now thats a good way to go! XSPC could make coloured acrylic to match their coloured tubing!
