Fluid Recommendations
19 Dec 2010
Morning all, I am planning on draining my loop this week and give it all a good clean, once it’s rebuilt I would like to change to a nice deep purple colour. Can anyone recommend any fluids that perform well, have a good deep purple colour and are not prone to solid fall out or separation?
many thanks
would you consider using a normal clear fluid and some dye? you can then make it as light or dark as your want. if so i would advise going for the same brand coolant and dye just incase they dont tell you something about how well it mixes with other brands fluid etc.
How about this?
https://www.xs-pc.com/coolant/ec6-recolour-dye-uv-purple
I use this XSPC coolant myself, very pleased with it and no signs of it clogging up or separating. Change it once a year or whenever doing maintenance, no signs of anything untoward going on. I tend to stay away from opaque coolants as I thought they were more likely to be problematic for separation/clogging up waterblocks etc....?
I only use Mayhems X1 now as I have had zero problems with it. It looks great, the 5 ltr container is reasonably priced direct from Mayhems and it doesn't stain blocks.
