I remember asking awhile ago that and people told me Fluid XP colours get clogged up and are not very good for pump ect. but then i look at project builds from ocUK and they all use fluid xp??? is it just for show or what? or is it fine to use it?
^ OCUK don't sell PT nuke or silver coils so they kind of have to use Fluid XP
but couldnt they buy a silver coil or is it there choice to use it because im sure if they didnt want to damage pump and have a lots of gunk they would buy some PT nuke or somthing?
profit then I guess
Fair enough, does no one else use coloured water? just coloured tubing then?
There is no difference between coloured fluid and clear fluid.
coloured tubing doesn't run the risk of clogging everything so it is widely used over coloured fluid
So if you used silver coil and PT nuke in water how often would you need to change water?
