Hey,
I'm running a simple setup (XPSC Pump/Rad combo) hooked up to a EK 360 rad, an i7 block (EK Acrylic/Nickel) and an EK 5850 Block (Acetal/Nickel).
I'm currently in the process of flushing out the old FluidXP to change it with some new EC6 stuff, and noticed lots of green crap clogging up the CPU block where the fins are. Now naturally i'm slowly getting some out (or so it seems) as i am currently running de-ionised water through it and have flushed this about 4 times so far and got some bits out, and just wondered of the best way to get the rest out?
I don't particularly want to open up the block as i'm scared ill muck something up, so any advice is appreciated!
Currently i'm running the CPU and Rad in the loop only at the moment in the hope that the pressure will push any of the gunk out of the CPU block, perhaps i could also remove the rad from the loop also? How about if i run the loop backwards so it pushes the gunk back through the way it came, would that help at all?
All of this is being done outside of my desktop so safety is fine, and nothing needs to be cooled so any suggestions welcome - and a bit of advice to anyone, don't bother with the Dye it's not worth it!!
