When flushing out new blocks/radiators. Very thorough and cheaper than you might think. I found a suitable submersible pump for £8.99 and the water filter for £20. Works a charm for getting pretty much any bad stuff out of my components left after manufacturing.
With my ek cpu block I found some particles tended to get trapped there, mainly dust and some plastic burrs because of the tight channels in the flow plate, might be worth a quick dismantle and clean.
