what causes a system fan to make subtle 'fluttering' noises?
if i listen to my rig, it doesn't sound 100% healthy. to me it should sound smooth and relatively quiet when running, aside from any normal 50hz hum from the mains power supply.
heatsink, psu and graphics card are all new. no other fans running, nothing else hooked up. new rig aside from cpu.
just to clarify, this isn't the kind of sound i'd expect from a fan, like a low, continuous hum or the flow of air over the blades. its more like the sound of moth wings fluttering maybe an electrical problem.
if i briefly stop the heatsink fan with my finger, the noise stops.
had this problem on two entirely different brand rigs with both old and new hardware.
When listening to multiple sound sources (example my lcd whine & my pc fan) there is a psychoacoustic effect. If you have say example 80hz on left and 60hz on right the difference is 20hz and this is heard as a vibrato sound like a fluttering.
thanks acetk. tried your test, noise is the same in both ears with and without finger. would be surprised if it was the fan itself though as i've had the same problem on both rigs.
ah ok itl defo be the fan then. cant remember who posted but i believe an NZXT fan literally exploded in someones pc the other day and even jammed up other fans lol.
it just seems such an odd problem to me as the fan is new and seems to be working well other than this. its had little use, no excessive rpm and been handled carefully during install. i guess i'll try the noctua fan and see how it goes, or failing this go h2o.
