FLV Splitting
16 Apr 2007
UK
Hey all,
I have a 2 hour long .FLV video to split. I have all the cue points ready. I was going to use a FLVParser I found on the net which lets you enter into CMD for example:
Code:
flvparser.exe vid.flv cue.txt
vid.flv being the video
cue.txt being the text document with all the cue timings for the splits.
It took ages to go through the whole video and find the right cue points and turns out the program will split the flv but after the first cue point it wont save it with video.
For example, it splits the flv upto the first cue point perfectly, then any other splits after that it will only save the sound!
Very frustrating :( However - I need another solution... any ideas?
Thanks,
Marky
