Flying through LHR to Iceland on wends, kit list check.
10 Apr 2004
Will I be ok with this lot through security:
Canon 40D + Canon BG-E2N Grip with two BP-511A batteries installed
17-55 attached + 4Gb CF card installed
10-22
70-300
50mm
430EX with 4x NiMH installed
Hoods
Another 4 CF cards
Another 4 AA NiMH
Another two BP-511s
Charger for Camera and Phone
Remote shutter
Eclipse Pads
Eclipse fluid, its flammable so check in luggage?
Small metal tripod going to check in luggage.
Hopefully all under 6kg but missing some things like lunchbox but I think i'll be under that :)
Cheers
all my chargers, tripod, cleaning stuff went in the checked in luggage - i only took the body, memory and lenses in hand luggage, just incase i wanted to take a pic in around the airport.
Yep, that's how I do it too. Anything that's normally in the camera bag stays there and gets carried on, everything else goes in the hold.
When i went to kenya i had fun at every xray machine!
goes through scanner - gets pull to one side as do i, asked if okay to go through bag and i say yeah sure.
THey have a look and my bag stowes the camera in a seperate part at the bottom. They go in from the top an cant find it! they looked confiused then i point out that its in the bottom. they look at the camera like they never seen a DSLR before.
Just make sure your bag is within the size limits.
My bag (just by 2cm!) goes through the bag limits, bit heavier than 6kg but sssh :p
ha ha well im fully expecting them do that. But as im within the limits they can shove it :p
not really 2 sets for camera and flash!
I am taking a charger, but as these things weigh next to nothing and take up next to little space its better to be safe than sorry.
In theory I should be able to take 4500 photos with the batteries I have charged.
But then again 3 might fail seeing as they are cheapies with one Canon :p
I run 6AA rechhargable batts in my 400D and 2x 2000mAh Li-ions in the grip. (not at same time) and hjave my offical canon as a backup if needed - i think only once i have got to the stage of using the official battery as i forgot to charger my others and my missus had nicked my rechargables for her P&S and put them back in the bag dead!
I'm going to Iceland on Thursday morning, weird eh?
I'm taking 1DS, 24-70, 28mm, 50mm, 580EXII, 580EX - batteries + laptop in carry on
20D, Sigma 10-20mm, Twin Lens MF camera, chargers/leads few changes of undies and 3 tshirts and an all weather in my check in luggage
