Just got a new mobo today (asrock extreme4 gen 3)
I put my i5 2500K in and there's power going to it but the motherboard has a small led display and it gets stuck on wither A3 or 64 (IDE enable and CPU DXE initialisation respectively)
I've tried reseating everything but it hasn't helped. I get no output at all onto my screen. The previous motherboard I was using now doesn't get power at all
Everything was working fine with the old mobo then I put the CPU I'm the new one and that doesn't work. I try it back in the old one and that doesnt work either.
Anything else I can try? If not, what to RMA?
Thanks
Thanks
