- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Silence is golden, so they say
Foam Silencing Kit for Cooler Master 690 II Cases @ £24.99 inc VAT
Using this pre cut noise reduction foam kit you can reduce the noise emitted from your case to give a more enjoyable time at your PC.
- Compatible with Cooler Master 690 II Advanced, Cooler Master 690 II Advanced Window, Cooler Master 690 II Lite, Cooler Master 690 Lite Window.
- 13 Sepeate Foam Pads
- Pre cut to size to dampen every part of your 690-II case
- Finely punched imitation leather
- Self adhesive tape pre-applied
Only £24.99 inc VAT.
ORDER NOW
ORDER NOW
