olv said:Focal length does not have a direct affect on the dof. dof of field is controlled by the aperture of the lens.
rpstewart said:The DoF is dependant on focal length. While the aperture provides the main control the DoF at a constant aperture is not the same at different focal lengths.
ie at a constant f/8 for 35mm film and a 10ft subject distance the DoF is:
50mm lens - 6.28ft
200 mm lens - 0.34ft
The actual reason for this escapes me at the moment...
If you want to see how focal length etc effects the DoF then check out this DoF Calculator
