Focus 1.8 Idle Problems
18 Oct 2002
Here!
Hi everyone!
I've been having problems with my zetec focus 1800 for a few weeks now. Basically when I pull up at lights the revs go up on there own for a few seconds and then drop again - it seems to be related to whether the car is moving or not because when I come to a complete stop thats when they go down. If I'm on a hill and just roll a bit in neutral it causes the revs to start increasing again.
Also when the revs do settle they still bounce very slightly. The problem gets worse after a long drive down the motorway or when the engine is hot.
I have replaced both the idle control valve and the throttle position sensor and still the problem persists. Please help before I pay WAY over the odds to get Ford to sort it out.
Thanks a lot.
Ross
I would have said icv, but seeing as that's been replaced the only other thing would be to check the vacuum pipe near the inlet manifold, it has a nasty habit of splitting.
Ben.
Is there an easy way to test if its leaking? I looked at the pipe when the engine was running and where it joins just under the inlet manifold it has kind of sucked itself together. Is that what it is supposed to do?
Also..I haven't taken my battery off since replacing the ICV and TPS so could the problem be as simple as doing that to reset the ECU?
Ross
I've lost my Haynes Manual, can someone scan a pic or point out where the ICV is on a 1999 Focus 1.6 Zetec engine? I'm having similar issues with mine (revs go up and down slightly when idle.)
Ta
My brothers Focus has always done this, if the car is rolling even quite slowly the RPM goes up, and once the car has been stopped for a couple of seconds it drops back to normal.
I thought if the speed sensor was faulty the speedo needle dropped to zero now and again, mine has never done that. How do i test for a vacuum leak?
Had a similar problem on an earlier zetec ford and found that changing the engine managment temp sensor solved the problem.
