- 14 Oct 2005
- Pembrokeshire
I have a 2008 Focus MK2.5 diesel which has developed a knocking/rattling sound around the nearside front wheel. It is very apparent when driving over rough surface, especially at low speed.
I've recently had new tyres fitted at an indie mechanic, who give everything a good shake at the front end and a poke with the pry bar but couldn't find anything amiss. He did find that my offside rear coil has snapped, right at the bottom, and I need need rear trailing arm front bushes, and my discs and pads will need doing soon, but none of these appear to be causing the fault. He was a man down that day so had no time to take it for a spin etc.
The car had a new alternator installed in October, then a week later a new DMF, clutch and cylinder (expensive month!), has done around 2000 miles between then and its last MOT in January without fault. About 300 miles after the MOT this rattle occured. The MOT guy did use a pry bar around the front and rear, but had nothing to say about parts needing replacing.
The knock can occur when accelerating briskly from lower speeds, or when turning towards full lock when parking etc. Took it out for a spin earlier, and noticed that while accelerating, my fans were speeding up, and the ABS/Traction/Battery/Another light were coming on and off. I didn't have my OBD hooked up at the time, stopped and hooked it up and found that when this was happening, the voltage was increasing to around 18.2V! I've read that the Focus smart charge system can increase the output to 18V to restart a dying battery, so I'm wondering if something around the NS front is shorting and pulling the battery down. I didn't use the car for a week, come to use it and the battery was too low to turn it over, had to use a battery pack to get it going. I've had the wheel off, the only wire I can see is the wire to the ABS module, which is seated fine. At other times the voltage lingers around 14.1 to 14.5. While driving, even if it's not knocking, the battery light occasionally comes on for a minute or so, then goes off, and I have noticed the headlights are flickering. The steering wheel also appears to want to sit slightly anti-clockwise by a couple degrees.
Codes pulled state losing communication with the Body Control Module, low voltage, high voltage
P1934 Powertrain
U0140 Network
B1317 Body
C2778 Chassis
P0625 Powertrain
U1900 Network
U2023 Network
It'll be going back in for the discs, pads, rear springs and trailing arm bushes next week, none of which appear to be the cause of this fault, so I am hoping to pinpoint what it could be before it goes back!
The car hasn't been driven a great deal since January, around 500 miles, as work is a few minute walk away now.
Any ideas?
P1934 Powertrain
U0140 Network
B1317 Body
C2778 Chassis
P0625 Powertrain
U1900 Network
U2023 Network
Any ideas?
