Focus fuel & temp gauges - is this normal?
28 Oct 2003
Worthington-on-sea
I don't usually drive to work as Mrs N has the car most days, but this morning I noticed something unusual. When I parked up & switched off, both the fuel & temp needles went to the usual 'off' position at far left and then after a couple of seconds jumped back to halfway position where they stayed. I switched on & off again to make sure and they did the same thing.
A quick google tells me that this is either perfectly normal or a problem with residual current. If it's normal, why haven't I spotted it before :confused: Should I worry?
This a Mk1 or 2? I have a Mk1 and it doesn't happen on mine, gauges should only register with the ignition on. As far as I know, that's the norm for most cars.
You could try the diagnostics mode by following the steps listed here. When you first try it, it should do a gauge test and the dials will run through a full sweep, if that helps.
definitely not normal, my 03 plate focus doesn't do this.
I would take it back to the garage that serviced it and say "it started doing this since you serviced it"
:p
The question is , if they go back to where they were - does the temperature guage go down as the car cools(with iginition off). If so i would be looking for an electrical fault (not shutting off). If not it could be a residual current issue of some sort as mentioned above.
